Exporting worksheets
Command
Path
Export Worksheet
General tab on worksheet tool bar
File > Export
Vectorworks worksheet files can be exported and read by spreadsheet programs, as well as by some word processing programs. Because these programs have different format requirements, several export formats are available. For example, a tab delimited text file can be opened as a table in Microsoft Word. The following formats are available:
Microsoft Excel (.xls, .xlsx)
Tab delimited text (.txt)
CSV, comma delimited text (.csv)
CSV, semicolon delimited text (.csv)
CSV merge, comma delimited text (.csv)
CSV merge, semicolon delimited text (.csv)
DIF (.dif)
SYLK (.slk)
When exporting to Excel, as much as possible, formatting, images, and formulas are preserved. An alert displays when exact translation isn't possible. Database header rows will have light gray fill, similar to the way they look in the worksheet window. You can export multiple worksheets to Excel format simultaneously with the Publish command; see Batch publishing.
To export a worksheet from a Vectorworks file:
Do one of the following:
Select the command from the File > Export menu.
Open the worksheet to export, and select the command from the tool bar.
The Export Worksheet dialog box opens.
Parameter
Description
Worksheet
Specifies the worksheet to export; if the command was executed from the worksheet, that worksheet name displays and cannot be edited
Format
Specifies the export format
Export Range
If the command was executed from the worksheet, specifies whether to export all rows or only the selected rows; otherwise, all rows will be exported
Recalculate worksheet prior to exporting
Recalculates the worksheet before export
Open file in the default viewer
Automatically opens the exported file in the default viewer application, if available
Specify the name and location of the exported worksheet.
